Allegheny
Weitere Links:
  • Eugene L. Huddleston / Thomas W. Dixon Jr. "The Allegheny - LIMA's Finest" - 1984, 2. Auflage 1996 Hundman Publishing - 245 Seiten - Library of Congress #84-80616
