Begriffserklärungen allgemein
Version vom 18. März 2010, 10:49 Uhr von wikipedia>1900
- AAR
- Ballast
- Bascule bridge
- Big Hook
- Big Wheel
- Bobber
- Bogie (engl.)
- Bolster
- siehe nachfolgende Einträge
- Bolster - Frame ...
- Bolster - Truck ...
- Boom car
- Boogy
- Boxcar
- geschlossener Güterwagen
- Brake
- Brake Wheel
- Bridge
- Bumper
- Bumper post
- Caboose
- Catenary (system)
- Clerestory roof
- COFG
- Cog Railroad
- Zahnradbahn
- Conductor
- Coupler
- Covered hopper
D - H
- Derrick
- DPU
- Engineer
- Express train
- Extra
- Fireman
- Flatcar
- Freight car
- Güterwagen
- Frog
- Herzstück einer Weiche
- Gondola
- Helper
- HEP ==> Head End Power
- Highball
- Hobo
- Hog
- Hogmaster
- siehe -> Engineer
- Hopper (open)
- Hopper bottom gondola
- Hot Box
- Heißes Achslager
- Hotshot
- Hump
I - O
- Ice hatches
- Ice reefer
- Incline
- Interchange Service
- Interlocking
- Interlocking tower
- Stellwerk
- Intermodal
- Interurban
- Journal
- King pin
- King post
- Light Engine
- Logging railroad
- Main line
- Main track
- Mechanical reefer
- Milk car
- Milk train
- MoW
- MU
- MU-hoses / -cables
- Narrow gauge (railroads)
- Observation car
- On the Ground
- Ore car
P - S
- Passenger car
- Piggyback
- Poling
- Poultry car
- Pullman car
- Pusher - siehe Helper
- Queen posts
- Road bed
- Gleisbett
- Road engine
- Reefer
- Ribbed Back Wheels
- Roller Bearing Truck
- Rotary snow plow
- Running boards
- Semaphore
- Flügelsignal
- Siding
- Siding - Blind ...
- Slim gauge (railroads)
- Standard gauge
- Stock car
- Stub (track)
- Stumpfgleis
- Superelevation
- Switch
- Weiche
- Switcher
- Switchback
- Telltale
- Terminal
- Track
- Track gauge
- Track pan
- Trackage rights
- Trestle
- Trucks
- Truss rods
- Turnout
- Turntable
- Drehscheibe
- Turnbuckles
- Uncoupling lever
- Van
- Ventilated box car
- Water melon car
- Way car
- Wye
- Gleisdreieck
- Whyte Notation
- Yard
- (Rangier-)Bahnhof
- Yard dog bzw. Yard goat
- siehe switcher
